Old Mar 7, 2011 | 02:24 AM
FUBU's Avatar
FUBU
Default Re: Side marker 2 indicator-mod [VIDEO inside]
Originally Posted by Larry Hitze
The electrical wizards here might correct me but aren't you supposed to unhook the negative terminal first then the positive? Also would a single filiment light or whatever work properly when there is 2 hot sources to the same wire? Would the power try to backfeed or something when both are on? Say you had the lights on and then turned the signals on, the bulb is already lit up why would it flash? Wouldn't you need a double filiment bulb like the tailights? Just asking for clarification.
Would be nice if some electro wizard helped you guys out for sure. I am not allowed to have the front side markers illuminated at all time. Only as indicators. Hence, no solution for both illuminated side markers and indicators was tested nor achieved.
