Old Mar 8, 2011 | 01:35 PM
maxcichon's Avatar
maxcichon
Default Re: Wheel guru's help needed...
I've not done this, but the rings should fit inside the bore of the spacer just the same as the wheel. Kind of a sandwich, but should work just fine.
The Eibachs come with a set of lug bolts to attach them to the vehicles hub. Then you'll need bolts to attach the wheel to the Eibachs. I would presume that the ones you have now will work for that.
