Originally Posted by svtcobra
I have a stock roadster srt-6, tomarow morning i will be getting the 185mm crank pulley installed with a flash tune from Jerry and then on the 21st get it dyno tuned. Can anyone tell what to expect by doin this mod and about how much boost i will be making
Probably somewhere between 18-21 psi of boost. You will need to get some aftermarket cooling put in place before the hot summer months come as the 185 cause the S/C to spin a good bit faster. Either go with the Supercooler from Needswings or talk to Eurocharges as they also have an aftermarket heat exchanger.
As for HP bump and such, it varies by car.
