Re: This always happens... Oil catch can install
yes, tapered threads on the catch can bottom port, it does not bottom out. don't over tighten or you can rip the threads out of the aluminum bung.
yes, the venturi port has the taller portion closer to firewall, pass side gets plugged since we do the 2 into 1 transistion inside the catch can itself.
yes, flip the bolt around on the psk bracket and clearances open up
