Great news i got the 185mm pulley installed and without the tune on a dyno jet dyno it made 295 to the wheels with the dyno tune it made 329 to the rear wheels. could have gotten more but jerry was say that the dyno jet dyno reads low and also i started to run lean so he dumped so extra fuel in the tune, but stated that i would need e55 injectors or a boster pump for extra fuel. Keep in mind the number are with no needswing intake so im guess with the intake and injectors i will be a lil over 350.
After driveing the car from the dyno with just the 185mm crank and tune can i say amazinggggggggggggggggggg 40mph under will shread the tires using the autosick cursing at like 30mph in 2nd gear dwn shift to 1st and punching the car movessssss the when the auto transmission changes back into 2nd the car will chirp the tires HARd friday i will be goin to my local track before i get the needswings intake to see what i run..
