Re: Need help - compression test?
Here's the link to all the service manuals, and everything else available for the Crossfire:
https://www.crossfireforum.org/forum...ollection.html
Short version is that the compression must be done with engine fully warmed up, and the readings must not be lower than 100 psi, nor must there be greater than a 25% difference between the cylinders. Make sure the throttle plate is wide open, or remove the throttle body from the intake manifold.
BC.
