Old Mar 13, 2011 | 06:22 PM
32krazy!'s Avatar
32krazy!
Default Re: 185mm crank pulley
Originally Posted by svtcobra
Jerry was sayin that he set it up where it would b safe to drive but i think i will take ur advise and go ahead and do the fuel before i take it out there but let me ask you this. Yesterday i found out that after i put the 185mm on the car my keyway on the crank broke. what could cause this and would the whole crank haft to b pulled out to change the keyway
that right there is why the c3 is so much better than the crank pullys!! it seems more and more folks take this route only to screw up the crank. if you sheared the keyway your crank is toast. in addition to replace it you are eliminating all the torque values that were used to hand build the engine. basically you just wasted a perfectly good hand built engine
if the keyway slipped out of position and the crank pulley spun on the crank you most likely have scored the crank . polishing may help but on the benz forums 9 out 10 cranks req. replacement. if you sheared the pin the crank has to be replaced. welding the keyway will throw the balance off
