Re: 185mm crank pulley
Originally Posted by svtcobra
yea im hoping i lucked out on it .......... do you think it was because of improper instillation when i bought the pulley jerry stated that if i dnt torque the crank bolt to like 350 i believe that it would mess up the crank. when my mechanic put the pulley on he used a impact so idk
the proper way to install the crank pulley requires a large torque wrench and a dial gage. you torque the NEW bolt to a specified torque then 90* more. the flywheel must be locked to prevent the crank from moving . if your mechanic isnt familiar with the proper procedure he shouldnt be messing with your car. if he is using an impact wrench you are inviting disaster. think what will happen when the pulley shears off the end of the crank at 100mph+ at the track. not a pretty sight
