Originally Posted by ontariobiker
Not sure what panel of fuses ? under the hood or beside the interior light switch? how did you hook into the fuse panel ?
Fuse panel is in the side of the dash on the drivers side, when drivers door is open you see the 2 round "locks" with slots to open the access panel. Open it and you will see the fuses. Pull the fuse for the fogs "see the picture I attached for the one to use" make sure you use the top slot where you pulled the fuse. clip the other end of the wire to the pink wire you will see in behind the fuse panel. It was tight to work in but can be done with some diligence and I took out the support piece you see in the picture with the philips screw for better access. I cut away the black tape and grabbed the pink wire and used a wire tap and clipped with needle nose pliers but looks like the way they did it in the picture was to stick the jumper wire right in with the pink wire. Not sure hoe they did that unless they took apart the dash to get to it? I bought the inline fuse holder at walmart for $2 and the wire tap is 20 cents and the bandaid from cutting your hand when trying to get the tap on the pink wire is 10 cents so your done for less than $3 all in. hope that helps.
PS what colour xfire did you get?
