Old Mar 17, 2011 | 04:31 AM
roctech's Avatar
roctech
Default Re: FS: Lots Of Crossfire Parts
Originally Posted by Never_satisfied
First, I would like to thank all the members on this forum for your support.
Kristy
Crossfire Parts:
Stock (Removed From Car)
Rims
Grill
Shocks
Rotors
Exhaust
Springs
2x Rear Upper Control Arms
Still In Box (Brand New)
Headlights Pair
Engine Fan Motor Blade Assembly
Steering Stabilizer
Teflon Coated Valve Covers Dark Grey
Mercedes Engine Cover
EVO Sport Pulley Kit & Belt (EVO.PER.MVS.PK1)
Drive-shaft Support and Bearing
NeedsWings Oil Catch Can Black
OEM Crank Shaft Sensor
Spark Plugs NGK Iridium IX Spark Plug Set (1 heat range colder) & Wires (Magnecor KV85 8.5mm Competition Ignition Cables)
Adjustable Front Camber or caster bolts Pair
Wet & Dry Air Filter Covers
74mm Throttle Body
Throttle Body Gasket
Sprint Booster (Limited and Base) Manual Part Number: SBCY0001S
Shuriken Light Weight Battery Kit Battery & Top
H.I.D. ( brights,highs, & fogs)
Goodridge G-Stop Stainless Steel Brake Lines
3 Bottles of Brake Fluid ( Motul 600 series)
Black Powdercoat Mesh Grilles Inserts (top & bottom)
NeedsWings Crossfire Naturally Aspirated Dual Cold Air Intake System Black
Hood Installation Pad w/ Crossfire Emblem
SRT6 Bumper Cover
BF Goodrich G-force T/A KDW2 Tires (Stock Size)
Carbon Fiber Hood (Pending Sale)
N/A Coupe Upper Window/Door Seals
Please feel free to contact me with any question or if interested in a part and we can discuss pricing according to your location.
Thank you, Kristy & Vince (Never_Satisfied)
Can i have info pricing on the dual air intake and 74mm throttle body please
