Old Mar 17, 2011 | 06:44 PM
Crossfire725's Avatar
Crossfire725
Default Re: Fuse 17 and 18 removed for some fun
Originally Posted by ZAHANMA
The wheel lock-to-lock trick is to get the BAS/ESP light to go off after a dyno or any other time you've removed Fuse 17/18. When you have those fuses removed I believe you have completely disabled the ESP system therefore the sensors that detect when your tires have lost traction are not functioning. These sensors being tripped by a loss of traction are what I believe causes the TC light to flicker or come on.
I think you are good to go as soon as you re-install fuse 17/18.
so if i remove 17/18 i have no traction control at all? on a 04 crossfire
