Originally Posted by x'ed
14.3@92?? what were you launching at, must have really nailed the 60'. i think you are actually the first person to take the manual to the track.
edited - forgot to hit post, thought I read it right.
14.3@92 was refering to WRX? ie Subaru WRX? Seen postings for a worked up WRX of 13.27@103.04mph, those 4x4's are quick to the 60 and not too fussy about the surface.
One of my favorite comments about my XF Coupe - "nice, looks like the Bentley GT Coupe". Just wish is went as quick. Flying 4x4 that hides it all. Before anyone needs to say it I know it two VW engines etc. Still nice.
Sub models: GT Bodystyles: 2-Dr CoupeDrivetrains: All Wheel Drive Transmissions: 6 Speed Automatic Engines:
2004 Bentley Continental Performance & Efficiency Standard Features.
- Two turbo compressor
- 5,998 cc 6 liters W 12 engine with 84 mm bore, 90.2 mm stroke, 9 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder
- Premium unleaded fuel
- Fuel economy EPA highway (mpg): 18 and EPA city (mpg): 11
- Multi-point injection fuel system
- 23.8 gallon main premium unleaded fuel tank
- Power: 411 kW , 560 HP SAE @ 6,100 rpm; 479 ft lb , 650 Nm @ 1,600 rpm
