Re: American market headlamp switch wanted.
Steve, Yes the Blaze Red is an amazing colour!!! Pop the hood and remove the fuse cover located on Drivers side, its #31 which is close to front, one side of terminal is live w/key . You can tap into this using a male connector, install a inline fuse and run wire directly to fog light, you can splice into this wire under the car,just turn wheels to full right and you can access thru the opening in the wheel well, let me know how you make out.
