Re: Headlight cover "foggy"
Thanks for the info. But I don't think this is the real solution. Moisture must pass of the headlights. If you use a plastic polish to avoid fogging on the lense, the humid air will condensate somewhere else. Therefore it's important to keep humidity out of the headlight with an appropriate ventilation, described in the TSB. I had mine installed but not working properly. Since the fix, no fog again.
