Old Mar 21, 2011 | 02:21 PM
dinasrt's Avatar
dinasrt
Default Re: Please respond - Intercooler Pump!
Originally Posted by martyfa
I replaced my stock pump at around 30,000 with a Johnson and now at 48,000 it's going out. Should I be looking for some other issue that would cause it to fail so soon?
Much appreciated
Did you flush your coolant system real good and change the fluid when you changed out pump, and use distilled water in the mix? Not saying this is the problem, but crud in the IC system can slow the flow and force the pump to work harder. My $.02
