Why do you need a cat back? So you can bolt on yourselt? Replacing the muffler on a Crossfire is about he easiet job a muffler monkey can do. I ran the Ansa tips for quite a while and then decided to put the stock tips on. It is easy to put your stock tips on. just cut off the Ansa ones as close to the muffler as you can. A saws all does a good job. You will find a samller inner tube that is the same size your stock tips. You can see my Asna with stock tips if the video above.
It's certainly easy, I just think it would be easiER for other guys in the future.
Mine is currently running the OEM tips and I LOOOOOOVE the way it sounds, I just don't like the way the rear of the muffler looks with the other tips hacked off. I know, it's nit-picky, but still...
