Re: Broken fog light cover: a repair question
The repair is simple. The challenge for me was finding a replacement fog light assembly. Once I found the assembly, I removed the damaged fog light, swapped out the internals (because the replacement did not match my OEM fog light), then installed the new fog light assembly. There is an access door in the inner fender that you need to open in order to remove and install the fog light. The repair took me less than 15 minutes. You should not have any problem figuring out how to do it.
