The issue I'd see with the larger ones at the edge of the wheel safety margin is that it's stuffed onto the wheel, and let's say at speed you're pushing hard in the corner and stressing the bead, there's a distinct possibility of it popping off. Not good. But probably wouldn't happen.
Does anyone else concur this statement?
Is there any possibility that a rear fitting of "285 - 30 - 19" could cause the tire to "pop" off the wheel?
If you are a spirited driver and have more than once exercised the max speed of the vehicle, would you be at risk? (SPECIFICALLY because of the specs of the tires stated)
Thanks,
FJP
