Old Mar 28, 2011 | 04:36 PM
freakingfastsrt6's Avatar
freakingfastsrt6
Default Re: Urgent - Wider Tire
Do not run a 285 on a STOCK rim...I run a 305 30 19 on 19x11 rear wheel! 285 and 295 should have at least a 9.5 or 10 inch rear wheel!!!
Originally Posted by Fjp3105
Does anyone else concur this statement?
Is there any possibility that a rear fitting of "285 - 30 - 19" could cause the tire to "pop" off the wheel?
If you are a spirited driver and have more than once exercised the max speed of the vehicle, would you be at risk? (SPECIFICALLY because of the specs of the tires stated)
Thanks,
FJP
