Old Apr 4, 2011 | 02:28 PM
tunaglove's Avatar
tunaglove
Default Re: CPS issue again? Maybe
If you didn't change the CPS yourself, check around the throttle body for leaks, this would include the hoses for the PCV system. Then put a fuel pressure gauge on the fuel rail and check that. Should be about 56 psi running. Also re-torque your manifold bolts and check the 4 clamps at the back of the engine, these are known to leak air also.
Air leaks and/or low fuel pressure can cause a lean missfire.
