Dave,
The only 'wiring' issue you may see is the brake wear sensor.... there should be a hole/slot for the senor to fit into...I had to 'adjust' the hole on the C32 pads for the SRT6 sensor to fit...you might be able to get away without them if you want... try unplugging one and turn on the ignition and see if you get a brake warning lite....
I THINK that when the rotor hits the sensor they wear the insulation off and create a short that turns the light on....
If you were in OR I could help you.....
