Check engine light
Hello to all. I just purchased a 2005 Roadster NA, Classic Yellow. Love it. Ive had it 2 weeks now, and last week the check engine light came on. Had Auto Zone pull the code and it was if I rememb er correctly 453. Anyway, it said emmissions fuel pressure to high. Possible fix was a possible corroded wire or a plugged fuel filter/ regulator. I replaced the filter,pulled battery cable to clear codes, and light stayed off for a day but now back on. My question is where is the tank, as it says possible cause for light on is corroded wire on tank. Im assuming there is some sort of pressure switch, and am hoping it is corroded. Does anyone know where it is located. Any help will be greatly appreciated, Thanks,
Dave
