Old Apr 13, 2011 | 05:18 PM
MMZ_TimeLord's Avatar
MMZ_TimeLord
Default How to recolor your switches! (lots of pictures)
Hello again and welcome to another part of the ongoing 'Purple Project'.
Today I will be showing you how to recolor your center dash switches. This includes your power window switches.
Once you have the switch assembly out of the center console, we can begin.
These are my switches after removing them from the dash trim.
I'll show you how to disassemble the simple switch and dummy switch first. They are the same except there are no active electronics in the dummy switch. Just a blank circuit board.
Pry off from both sides, the rocker portion of the switch. Then unscrew the two small screws on the back. I recommend a #1 precision Phillips screwdriver.
Inside there is a circuit board with pins going out through the plug side of the back. You may need to push these pins back through the plug housing to release them.
On the circuit board of the switch (Tow alarm disable in this case) there is a single red, indicator LED and a switch with a clear lens, green LED in it. We want that switch!
The switch is soldered to the small circuit board in four places. I've marked them with green arrows in the top of this picture. You will need to de-solder these points and remove the switch.
Once removed, on the bottom of the switch, there are two 'weld' points, marked with green arrows in the middle of the picture. These will need to be ground off or drilled out. I drilled them out with a hobby drill bit I had. use a hand hobby drill, Moto-tools are just not very easy to control this small.
Once those are drilled out far enough, you can pop out the LED from the switch. I've disassembled the whole switch so you can see it here.
Once you have the old LED out you can replace it with the color of your choice. The LED size is 3mm. I used Super Bright UV Purple.
Next I went on to tackle the power window switches. These are a different animal, but easier in one respect. You do not have to de-solder a switch and then drill out the LED! YAY!
Once the switch is apart, you can simply de-solder the LED. But wait! That's not a regular LED lens!?!?!? WTF? Oh, crap it's an inverted lens. Designed to put light out of the sides instead of a beam in front.
Break out the Dremel and turn my own LED to the same shape lens. Worked pretty good.
Next two things to tackle are disassembly of the center section with the hazard switch.
Remove the six Phillips screws on the back and pull off the front housing. Then remove the hazard switch and springs. (You can leave the springs on the lower housing like in the picture, I just took them out of my way to work)
You will have to de-solder seven points. I've marked them with green arrows. Once the board is de-soldered from the pins, you can remove it and proceed to change the LEDs in the two small switches.
Last I did the heated seat switches. Once again, these are the same type of switches that are just soldered to the board. It's getting to them that I'll show you here.
Start by removing the four small, greenish (on mine anyway) colored screws. Two at each end that secure the casing together.
Then you must carefully pry out the electrical runners. Be careful to release the tabs and not bend them backwards. (I did on one, but was able to bend it back without breaking it.)
Next, there are two lock tabs in the center channel holding the two halves together, release these and remove the front shell half.
Now you can tilt out the two end circuit boards and de-solder the two switches on each. Just change out the LEDs and solder the switches back in and re-assemble.
Oh yeah... RESULTS! The first picture is a bit blue due to my camera not being able to see UV. So, I made a slight adjustment on the second one to reflect closer to real life.
