Old Apr 15, 2011 | 08:46 AM
onehundred80
Default Re: Cyclic Drill Noise At Idle... ???
Originally Posted by ant.lan
the car when is at idle also shake a little bit this is related with the p0410 secondary air problem?
i replaced:
-camshaft sensor
-crankshaft sensor
-spark plugs (bosch fr88dpp33+)
-air filters
-fuel filter
and cleaned MAF sensor and THROTTLE BODY
but the car is still shaking and rambling a little bit,
ANY IDEAS??????
Vacuum hose leak?
You had the MAF off, did you install both vacuum hoses correctly?
Look at hoses to air pump.
