You do need an electrolyte to start any corrosion, in dry conditions you are OK.
Salt spray and your engine will disappear.
What about the copper crush washers?
You are absolutely correct...you need moisture. Would a seepy gasket allow enough moisture to start the corrosion process, probably not. But is it worth risking?
