Old Apr 18, 2011 | 07:49 AM
  #49 (permalink)
Larry Hitze's Avatar
Larry Hitze
Default Re: Oil Change with Topsider or similar
Originally Posted by patpur
It's so easy to just drain it. I've heard pro's and con's on exactly how much "stuff" the topsider actually gets out so I'm happy to spend a few minutes under the car and use the drain plug method. It does help if you have a garage, hydraulic jack and jack stands. If you do drain from the pan jack up the drivers side of the car. The drain plug faces the passenger side.
Pat
I agree with my ramps it doesn't take me an hour to change the oil and that is letting it drip until it stops completely. This way maybe any heavy particles if any will drain completely out.
