Old Apr 18, 2011 | 11:53 AM
  #55 (permalink)
bri3d's Avatar
bri3d
Default Re: Eurocharged Tune + Remote Flashing Cable - $265!!
The Eurocharged cable is a Galletto cable - *not* a "standard" USB<->OBD2/CAN(Serial) cable like an ELM327.
You can't use the Galletto cable (at least not in its stock form with any existing software) to read sensors / OBD-II data, and you can't use a "standard" ELM cable to flash the ECU.
So if you want to both read/display data and reflash the ECU you'll need two different cables at this point.
