Re: Spare key won't work
Originally Posted by Goldwing
Spare keys have to be individually laser cut to the VIN, and you can test that by unlocking/locking the driver door manually. If that works, do a search on the forum for setting up a new key. It's a 3-4 step process and very easy. I believe if it turns the ignition and the car does not start, they key has to be set up as I mentioned above.
Seemingly the key turned in the ignition so I guess it will fit the doors.
The keys are not laser cut, they are machined.
