Originally Posted by Crossfire725
I ment a pic of the pad drop. If I went 5mm front an rear how much lower would the car be then stock? An you sed u cut ur springs? How much did you cut off and you got a pic of that? I'm just lloking to tuck the wheels a lil better then stock. Can I do that with just the pads? Or do I need to cut and pads or just pads?
As mentioned earlier, I'm not sure how much drop you'd get because I don't think there's a set constant as to what the cars come with from the factory. Mine were 3/1, I think Nick had a 4/2 and Jason had a 3/2 (As in, dots per pad).
I bought the springs already professionally cut, but if you want before/after shots just look in my gallery. The "wing installed" album is at stock height. The shot with the Mandrus wheels is lowered.
