Thread: blown subwoofer
Old Apr 19, 2011 | 05:30 AM
bigblock427's Avatar
bigblock427
Default Re: blown subwoofer
Originally Posted by Aintgonnahappn
Sorry to bring up an old thread. Picking up a srt-6 this weekend and was wondering if there is any merit to this post after I have found multiple posts that state its a direct fit, and then this post which worries me. Did he not know what he was doing?
As far as i know there are no after market speakers that will fit without light modifications on the housing.
The Kickers will also need modification on the housing. And they are not designed for free air use.
I've bought a pair of Earthquake SWS 6.5. SWS The Original Shallow Woofer
The pro on them is that they are designed for free air usage and the sound much better than the original subs. The go a little bit lower and they don't have that "boom boom character" that most try to compensate with the capacitor solution.
The con is that the mounting diameter is 6 mm wider than the original mounting hole, so you have to modify it. And that they have only a efficiency of 77 dB. So they need a little bit more power than the stock amp has – even if you bridge the 4 x 22 watt to 2 x 44 watt for the subs – which is possible without a problem.
For those who are interested in, these are the technical specs of the Eathquake SWS 6.5:
Revc: 3.6 Ohms
Fo: 39.31 Hz
Sd: 12.50 msqM
BL: 4.350 TM
Qms: 4.192
Qes: 1.723
Qts. 1.221
SPLo: 77.3 dB
Vas: 9.94 Ltr
Xmax: 15 mm (measured in one direction)
Speaker diameter: 6.5"
Mounting depth: 1 3/4" (45 mm)
Cut out mounting whole: 5 3/4" (142 mm)
Weight: 5 Lbs
Voice coil diameter: 1"
Aluminium bobin
Power rating RMS: 100W
Power rating Max: 200W
