Old Apr 19, 2011 | 10:02 AM
  #56 (permalink)
onehundred80
Default Re: Oil Change with Topsider or similar
.........Multi-grade oils perform equally as well at both low & high temperatures ranges.
At the low end of any particular multi grade oil temperature range it does not operate as well as its upper end. It performs adequately.
All oils get thinner as their temperature gets hotter, some more so relative to others.
All oils get thicker as their temperature drops, some more so relative to others.
A cold engine will suffer more wear until it gets warm.
An overly hot engine will suffer more wear until it's temperature drops to a safe temperature.
Both of these reasons are because the oil film is too thin or non existent.
