Originally Posted by 32krazy!
brianbrave did the whole project remote tank and all. end result was once the ice melted the fluid throughout the system became the same temp. not so much heat soak but becoming consistent temp throughout. no real benefits to be found.
Yes, that's true but then when you start boosting again it will take longer to heat the larger volume of coolant.
