ok i will check that out later today. but i know for sure that they use the Larger Drilled Rotors. See Picture!
Part Number For the Larger Drilled Rotor: A2034211312 please Double Check with the Dealer.
A Nice Paint Job on these and they will look sick :-)
Look for a number on the mounting area tabs. This will tell you what size rotor they work with. These will work on a Crossfire if you use the rotors from the same car the calipers came off of. These are two piston which is not really a performance improvement but they do look better than the single piston floating caliper that came on the Crossfire.
