Old Apr 24, 2011 | 06:47 AM
32krazy!'s Avatar
32krazy!
Default Re: front camber kit
to completely understand the idea you need to get under the car and see how the bolt is installed now. then envision the new bolt in place with the flat spot on the washer against the stop on the a arm. rotate the washer and then it will become clear how the washer changes the camber. the idea is simple but the actual labor to do it is a bit involved
