Re: front camber kit
When you remove the old bolt you will see two" v's" on each side of where the stock bolt was inserted. The new bolt can be inserted to increase or decrease camber and the washer help to lock it into position. I did all four by replacing one at at time. Took some work but my alignment is perfect after lowering the car.
