Old Apr 24, 2011 | 05:37 PM
shortfellow's Avatar
shortfellow
Default Re: front camber kit
When you remove the old bolt you will see two" v's" on each side of where the stock bolt was inserted. The new bolt can be inserted to increase or decrease camber and the washer help to lock it into position. I did all four by replacing one at at time. Took some work but my alignment is perfect after lowering the car.
Tnx for the reply. Let's say I have the bolt in properly. What I don't understand is how to adjust it. Do I adjust the camber by turning the bolt or by turning the washer. Out of all the advice I got that remains a mystery. I thank you in advance for clearing this up.
also I assume that I only replace the front bolt. Is that correct?
