Old Apr 25, 2011 | 02:54 PM
onehundred80
Default Re: High Beams Out - Not the Switch, Though
Originally Posted by Toddy
Thanks a lot for the info. So, seems pretty likely it's the multifunction switch? Sounds like something I'll need to go to the dealership for, because based on the instructions here elsewhere, this is some work I won't want to do myself.
It's your money but soon to be someone else's by your remarks.
I think you misread the posts if you have concluded it's the multi function switch. The switch and illumination module probably cost $500-$600 together plus labor. I would want to know what, if anything, was broken before I trusted the stealership with my car.
Go into the stealership and you will come out $1,000 lighter if you are not careful.
