Old Apr 27, 2011 | 02:46 PM
Rowanbud's Avatar
Rowanbud
Default Re: Worst Nightmare: Engine Warning Light!
It seems highly unlikely it was the gas cap that actually caused your engine to stall. It sounds like your gas cap was tight anyway holding pressure the way it should.
I would suggest you might need to purchase a solder iron in the near future.
https://www.crossfireforum.org/forum...-no-start.html
James
Ok! It looks like you are right about this one! Won't start now but all electrics working. Just had a diagnostic done by the breakdown organisation & it's comming up with something like 'crank shaft sensor' ????? Signal failure so car doesn't know when to send fuel (am I making sense?) he doesn't know if it's the sending or the recording of the signal that's the problem. So, if it's the relay module thing - sorry but technical stuff isn't my thing at all!- could that be the sensor that is mentioned in this post? Would be grateful for any advice!
