Old Apr 27, 2011 | 03:25 PM
onehundred80
Default Re: Worst Nightmare: Engine Warning Light!
Originally Posted by Rowanbud
Ok! It looks like you are right about this one! Won't start now but all electrics working. Just had a diagnostic done by the breakdown organisation & it's comming up with something like 'crank shaft sensor' ????? Signal failure so car doesn't know when to send fuel (am I making sense?) he doesn't know if it's the sending or the recording of the signal that's the problem. So, if it's the relay module thing - sorry but technical stuff isn't my thing at all!- could that be the sensor that is mentioned in this post? Would be grateful for any advice!
It is the crankshaft position sensor, NOT the relay control module. Change it asap as it will not get better only worse. They are reasonably easy to change. Not sure of the price in the UK $60 - $100 in NA.
https://www.crossfireforum.org/forum...tml#post143294
