Old Apr 27, 2011 | 06:24 PM
onehundred80
Default Re: Headlamp / Foglamp Condensation
Originally Posted by TiredRetired
Noticed it today while washing my CF. A search here found a wealth of info on this subject and found the TSB info on it and will purchase the kit shortly. All condensation went away in less than an hour without using the headlights.
My question is, I also noticed a very small amount of condensation in the fog lamps. Is there anything one can do about that? Did not see much info regarding this.
If you get the kit, keep the old caps and you will be able to modify them if you install HID's.
If you have already got HID's keep them as spares in case you go back to OEM specs for some reason, you never know.
Some of the kit (one cap and plugs) and an OEM cap and vents.
I never had condensation problems at all and I attribute it to DTRL's, major problems I think are caused by a leaking headlamp unit.
