Old Apr 27, 2011 | 06:50 PM
onehundred80
Default Re: Headlamp / Foglamp Condensation
Originally Posted by TiredRetired
I saw where you had mentioned this to someone a couple of years ago or so. Are you saying there is a leak/crack between where the clear front mates to the housing? If so, I am assuming that the most logical fix would be a thin coat of clear RTV all the way around the housing.
I guess, at any rate, I should try the TSB fix first and see what happens. Your DTRL theory sounds plausible. I always use my headlamps while driving. Of course, they are not on while washing.
Some people pooh poohed this idea when I raised it at first but with the amount of water in the units some people had they looked like a suitable habitat for frogs. I did not think it was from humidity unless they lived in the Amazon rain forest, so it had to be leaks. Later someone said they had found the leak and it was the seam.
