Old Apr 28, 2011 | 06:00 PM
downwardspiral's Avatar
downwardspiral
Default Re: Resistor for IAT
Originally Posted by Yanksmell
Hope this helps you understand what fooling the IAT sensor will do for you.
You are not tricking anything, you are taking the air tmeperture out of the equation and forcing the ECM to control timing via the knock sensor.
I am also a Ford engineer, and I own a horse. From what I understand, the engine is run with magic. The magic flows through the IAT, into the ECM, and exits the engine in the form of carbon monoxide. The resistor will limit the flow of magic through the IAT, thus producing less CO stoichiometrically, and thus making 20+ LESS HP.
