Old Apr 29, 2011 | 10:44 AM
Yanksmell's Avatar
Yanksmell
Default Re: Resistor for IAT
I am also a Ford engineer, and I own a horse. From what I understand, the engine is run with magic. The magic flows through the IAT, into the ECM, and exits the engine in the form of carbon monoxide. The resistor will limit the flow of magic through the IAT, thus producing less CO stoichiometrically, and thus making 20+ LESS HP.
First off, you are not a Ford Engineer. Ford would teminate ANYengineer that talked like you do. Ford has no engine control design in NY. At 23 and only 1 year out of college at Ford would make you a go-for (at best). You may be a Ford mechanic (at a dealership) and you may be an engineer but you most defintly are not a Ford Engineer.
You say you own a horse, what part of a horse is speaking when folks are trying to understand the IAT sensor input to the ECM and you start a diatribe of magic and foolishness. As you state so clearly, "from what I understand, the engine is run with magic" is correct to you since you seem to have only enough IQ to view the subject as "Magic"; offer somthing of substance rather your verbal vomit of crap talk.
If your so smart, you explain how the IAT sensor functions.
I suggest you take your view back to 5th grade where this sort of crap is cool. GROW UP CHUMP! Help people with their questions or SHUT THE HELL UP!
