Old Apr 29, 2011 | 12:45 PM
onehundred80
Default Re: Oil Change for cheaper?
Originally Posted by PitMarshall
If one is using a TopSider, over time, how effective is this method in getting rid of physical "elements" (crud) in the oil. Gravity and draining would go a long way to clearing that problem compared to sucking it up through the tube.
Too, I wonder if there is a magnetic drain plug from the factory that would capture filings ad the like. The topsider would not get any of that.
I have a new topsider and I've been wondering just how effective it will be and how often I really need to get the car up and drain it. I'll probably only change the oil annually based on anticipated use.
Any thoughts?
If there is no magnet on the drain plug and the drain plug is made of steel, I think one of those rare earth magnets stuck to the inside of the plug would do the trick.
Those suckers are so strong it will not go anywhere.
