Old Apr 29, 2011 | 02:15 PM
freakingfastsrt6's Avatar
freakingfastsrt6
Default Re: Centric drilled and slotted rotors complete with posi quiet brake pad set for sale
I've been getting a lot of questions regarding Ceramic and Semi met brake pads....so Im gonna write a quick over view!
Note: this review is for the pads I sell POSI QUEIT
Semi Met brake pads= have the LOWEST AMOUNT OF DUST, when the other guys are telling you that ceramic brakes offer the lowest amount of dust they are wrong! The semi met brake pads will hold their own against any ceramic pads in real world driving and occasional track...though not recommended~I will always suggest Ceramic for track use along with a slot only rotor application.
Ceramic brake pads= These offer outstanding performance over semi met in high temp braking areas, will have better fade resistance under pressure and higher operating friction levels....but give off more dust under friction, still offers low dust count over stock but not as good as the these semi met but will offer less noise than the conventional semi met pad.
If you should have any other questions please don't hesitate to ask...
thanks for reading
