Re: Resistor for IAT
Not to mention the voltage goes up as the temperature goes up, as the sensor's resistance will increase (heat = resistance.. R=V/I ). A resistor will trick the sensor into reading a higher temp. If anything, the ECM would pull timing to compensate for the high temps.
I mean.... I am a ford engineer and own a horse.
