Re: How To - Transmission Filter/Fluid Replace
Originally Posted by silverfish1
im going to be draining my Trans fluid and also putting in a new Trans filter in.
Have you done this before.
Since i dont have anything to messure the fliud i am going to drain out, the owners manual says fill back to 8.5 qts
your thoughts? and have you done this-
Thank you,
If you're just dropping the pan and changing the filter it will only need about 5 quarts. If you drain the torque converter and flush the cooler then you will need 8.5 quarts. You can buy the dipstick tool if you want to check the fluid level.
http://shop.ebay.com/i.html?_from=R4...All-Categories
