Old May 4, 2011 | 10:03 AM
DarkKnight88's Avatar
DarkKnight88
Default Re: Turbo the V8 - your car could be next!
Originally Posted by cw_double
This is great. I would love to Turbo my n/a. What would be the shopping list for this project. I am not much of one when it comes to any kind of forced induction set up.
Where do can you purchase a 32 Komp ECU?
I was wondering the same thing myself. The ECU should be available with the engine though depending on where you get it, but what all else would be needed? A brake upgrade most likely, but other than that? The turbo, intercooler, wastegate, boost controller, intake, all the normal turbo setup supplies, but would there be anything else that would be different in this case? It'd be limited to pretty low boost though due to high compression in our N/A, that got me to thinking about some of the things done with Nissan to rectify those kinds of problems. What about a head swap to the 32k head and swapping out our pistons for dished ones to lower the compression and then turning up the boost? Any thoughts?
