Thread: shifter knob
Old May 5, 2011 | 04:40 AM
eikon's Avatar
eikon
Default Re: shifter ****
The **** is also glued in place.
Take a single edge razer blade and gently work it all around in the joint. Go slowly and take your time so you do not damage the surfaces. After doing the cutting, tape up the bottom piece so you can prevent damage when you use a vicegrip (set with only enough pressure to grip the layers of the tape) and gently turn the piece.
Good luck!
