Old May 6, 2011 | 10:17 AM
oledoc2u
Default Re: How does one get the crossfire rear on jackstands?
you guys are so funny....jack up either on the front and back jack point, and watch what happens>....
I have lifted the car high enough to place 3 jack stands under it from one jacking point, not recommended, but is possible...these little dudes are rigid. Recommended would be use the back jacking point to place the front jack stand. But if working only on the rear then, reverse this....good luck...I also place a small piece of wood between the car and the jack to protect the car...a piece of 2x4 will work...
